Problems with a few games, dont know why?
7 Mar 2010
Cardiff
Hey,
Was wondering if anyone could help me, recently I have been have trouble running some games smoothly even though the FPS are around 50-60. I have read that the Radeon 5770 has driver problems, could this be it as i dont think it is the rest of my system!?!?
When you say recently, can you identify a specific time when it changed?
What drivers are you currently running? Try going back to Catalyst 10.3s..
I see from your sig that you have an Asus 5770.
Do you have Asus GamerOSD installed? I had similar issues with my 5870, removing GamerOSD fixed the issue for me.
Umm its been happening within the last couple of days, since i installed catalyst 10.5. In games such as BC2, assassins creed 2 and mass effect 2.
Will go back to 10.3 and let you know what happens, i will also remove gamer osd and see if that makes any difference.
Thanks for the help!
I uninstalled 10.5 and installed 10.3 and also got rid of gamer OSD and now everything is running great!
Thanks, i really appreciate the help!
