Crossfire 290's installed
Only issues were :-
a) When first booting after install it started but turned off before booting into bios/windows - exactly what happened when I added hardware before so may be part of standard operation![]()
Thats normal, as mine does it everytime i switch on, it comes on for a split second, before going back off, then it comes back on again and boots, i forgot what it is though, might be some sort of selftest![]()
Which DDR4 are you using LoadsaMoney.
I found Gigabyte X99 SOC Force To be nightmarish for glitchs but the ASUS X99 S though better in some ways still has its fair share problems. Intel needs to put a lot more work into the Haswell-E platform.
what outstanding x99 issues do potential x99 purchasers need to look out for?
I have recently gotten a Asus X99-S board and have had major issues with the USB2 and USB3 ports.
I have the latest BIOS and have installed windows at least 3 times. The best I can get is that I have to unplug all of my USB2 joysticks, Thrustmaster Warthog and Fanatec pedals from the main board at boot otherwise the whole machine will lock up on boot.
It will boot with no problems if I keep them unplugged, then plug them in after boot. I can plug them into USB3 or USB2 after boot with no issues, just not have them connected at boot. Tried everything in the BIOS and clean installs. Nada.
Also noticed the Win7 start up animation freezes on every boot in time with the keyboard being given and lost power during the start up phase.
Hi,
Makes sure USB boot is set to fully initialised under boot options and see if the problem persists. There are issues with certain legacy devices
I am also having issues with my USB 3 ports, seems a common problem. First and last time I buy an ASUS MOBO.
