Problems with booting
26 Dec 2003
Well, its actually quite a large problem! The motherboard is Gigabyte GA-890GPA
I've been trying to OC recently, all was going well. Had it running stable for 2 weeks at 3.6, 0.5 undervolted. I did this to see if it helped the temps. Anyway, I thought I'd try to undervolt it more. This caused a BSOD on Win 7 boot. Comp reset, now nothing. Just says no signal detected.
Soo, I guess I need to reset the Bios or something? I'm sure I've seen a short cut key on the motherboard splash screen, but I can't remember what it is.
Any help would be appreciated. Thank you
there will be a clear cmos button or a jumper to move around on the motherboard to reset the bios to default settings, read the manual.
theres is a clear CMOS jumper to the left/up a bit of the battery, it should not have a jumper shorting it, remove the power, apply the jumper across the two pins, remove the jumper and power back up.
19) CLR_CMOS (Clearing CMOS Jumper)
Use this jumper to clear the CMOS values (e.g. date information and BIOS configurations) and reset the CMOS values to factory defaults. To clear the CMOS values, place a jumper cap on the two pins to temporarily short the two pins or use a metal object like a screwdriver to touch the two pins for a few seconds.
• Always turn off your computer and unplug the power cord from the power outlet before clearing the CMOS values.
• After clearing the CMOS values and before turning on your computer, be sure to remove the jumper cap from the jumper. Failure to do so may cause damage to the motherboard.
• After system restart, go to BIOS Setup to load factory defaults (select Load Optimized Defaults) or manually configure the BIOS settings (refer to Chapter 2, "BIOS Setup," for BIOS configurations).
