- 27 Jan 2003
- Chesterfield, UK
Greetings,
Bought 3x 2GB Kits off the "This Week Special" and I'm having difficulty running the memory on either the P5B & DS4 at default voltage and default clock. I have lost 1 install and had problems installing with this memory.
The question I'm asking do I need to crank the voltage up to 2.1 Volts to run at the rated SPD spec with everything on Auto?
If this is the case what is normal on the DS4 with regard to voltage. Is Normal 1.8 volts? If I have to overvolt the voltage I need to know the reference because its all 0.X over reference.
