Hello forum peeps,
I just wanted to post this as I am having major issues with a PC I bought from OcUK. All the parts were recommended to work together and from the sounds of a lot of people on this forum they have very similar setups.
Here is my Spec: (all parts were brought from OcUK).
Intel Core 2 Quad Extreme Edition QX9650 "LGA775 Yorkfield" 3.00GHz (1333FSB) - Retail
Coolermaster Real Power 1000w Modular Power Supply
Coolermaster Stacker 830 Evolution Nvidia Special Edition Case - Black (No PSU)
Zalman CNPS9700-NT nVidia Tritium CPU Cooler (Socket 754/939/940/AM2/LGA775)
BFG GeForce 9800 GX2 1024MB GDDR3 TV-Out/Dual DVI/HDMI (PCI-Express) - Retail
Asus Striker II Extreme nForce 790i Ultra SLi (Socket 775) PCI-Express DDR3 Motherboard
Corsair 4GB DDR3 DHX 1600C7DHX Twin3X (2x2GB) (TWIN3X4096-1600C7DHX)
Western Digital Raptor 150GB 10000RPM SATA 16MB Cache - OEM (WD1500ADFD)
I have set the memory on the motherboard to be unlinked, to enable the 7-7-7-20 Timings and the 1600mhz speed with 1.90v on the memory on the board.
Now Here is my Issue:
When playing any game on this system (was brought for high end gaming) after a short time the machine freezes with sound looping, sometimes it BSOD then rebooted or sometimes it just rebooted if left long enough.
After sending the Memory back to OcUK (after running memtest86 I discovered the memory was faulty). So that cured one problem, no longer did the machine crash and cause a BSOD.
However the random freezing with looping sound in games and rebooting still occured.
My First thought was to update drivers - that didnt fix the problem
Secondly I did a bios Update. now running 1106 on the Striker II Extreme. - That didnt fix the issue.
I purchased Windows Vista 64bit (due to the memory only showing 2.75gig on Windows XP (32bit)).
So I downloaded all the latest drivers and reformatted. - Still the same problem, freeze then reboot.
I really was at a loss, someone suggested it was the OS, being too new even though the parts were only brought last May.
So I reformatted and installed Windows XP (32bit), and this time put the drivers that came with the motherboard and BFG grahpic's card in. - Still crashed and froze.
I had looping sound and a freeze then a reboot at this point. I removed my sound card (sound blaster) and put in the Striker II Extreme HD Soundcard.
I checked the windows system logs, using the event manager; This showed a nvidia error with the GPU. So i followed up on some nvidia forums and got told the graphics card may be faulty, and this is the cause of the freezing.
Error Message:
Unknown error on CMDre 00000000 00000000 00000000 00000001 00000001 The driver nv4_disp for the display device \Device\Video1 got stuck in an infinite loop
I even changed the ports on the PCI-E slots to see if that solved the problem, it did not.
So Last friday I sent back the graphics card to OcUK, with all RMA and details of what nvidia had told me. So to minimise the downtime, I brought the new BFG GeForce GTX 295 1792MB GDDR3 TV-Out/Dual DVI (PCI-Express) - Retail (BFGRGTX2951792E) from OcUK.
However now I have the same problem with this graphics card. Firstly i did all the correct methods of installation, I reformatted just after I installed the card, that way I would have any driver conflicts etc.
I put windows Vista 64bit back in as the card is newer than the OS, with the drivers from the website (all the latest ones). Now playing anygame in window mode freezes the computer. I get a sound loop at the same time still.
Thinking again this could be the striker II's HD sound card i removed the card, reformatted and still have the same problem.
I have tried both combinations of the PCI-Ex16 slots, both have the same issue. Is this the motherboard thats at fault?
I have ordered a new motherboard, this time gone with the new intel chipset instead of the nforce one. However if the board is faulty which is the better board? Asus Rampage Extreme Intel X48 (Socket 775) PCI-Express DDR3 Motherboard
Basically once again i am now building a second rig, to be able to test the parts properly, but I am having a feeling I will send the motherboard back to OcUK anyway. I know lots of people with the same GFX card and the same mobo that do not have these issues, it seems to always happen to me.
Its a rather expensive way to go about building one rig. Short of driving down to OcUK to talk to their technical department with the PC I do not know what I am doing wrong, or if its just my luck with faulty parts.
Anyone care to shed some light on the situation, or advice?
Error Message:
