Problems with my Audigy
20 May 2006
Hi, I have a creative audigy soundcard currently fitted in one of my pci slots
the card looks like this, "Sounblaster Audigy 7.1 se"
When I boot up the computer after fitting it, I get the message that a new multimedia audio controller has been detected, and I choose to install it automatically. The drivers are then automatically installed.
I go into the device manager and its there in the audio section however I have no sound. I then try rebooting to see if this will fix the problem and then I go into device manager and the entry for the audigy has vanished :mad:
Ive tried both available pci slots and the same happens in both. I have disabled ac97 audio by selecting disable in the BIOS.
You need to install the drivers that came on the CD and not let windows use it's own drivers.
You need to look on the web for them or find your CD that it came with. :)
