Problems With My PC
17 Jun 2005
Ashby, UK
Hi,
When i run my pc it loads up fine but after a while some times it restarts itself. i reformated about 2 months ago to get rid of some rubbish on it but it keeps doing it.
Does Anyone know what the problem is?
I am running Windows XP SP2
Does this problem occur at regular intervals or only under heavy use? e.g. is there any sort of predictable trigger? Have you tried running memtest86 or prime95? What sort of voltages are your rails?
Sorry lots of questions but at this stage it could be almost anything. As a shot in the dark I'd suggest memory as the most likely cause because memory is often the most flakey component.
It happens mostly when im playing music or on msn or both. i thort it was my pc overheating but i checked the temp and it was fine.
robhough said:
Hi,
Assuming you didn't go inside the PC and play around with hardware, and that it was fine before the change (and that it started doing this as soon as you had reformatted).... I know lots of assumptions...
... my guess would be a software / driver issue.
It's more likely than a hardware fault that just happened to occur at the same time as you made a software change (although this isnt impossible).
M
