Hi
I have just put together the following pc
4790k cpu
Gigabyte z87-ud7-th
2x8gb hyperx ddr3
480gb corsair mx100 ssd
Dvd writer
When turning it on all I get is a blinking underscore on the top left of the screen. There is no bios post / splash screen. The code on the motherboard reads as A9 - bios is initialised.
After doing some reading I found that perhaps the mobo does not support the cpu and I would need to flash it to the latest firmware. I looked on the Gigabyte website and it said a G1820 CPU is supported from the initial release so I bought one of those only to find it does exactly the same thing.
I have tried with single sticks of memory and nothing.
This is driving me nuts so any help is appreciated.
Thank you
4790k cpu
Gigabyte z87-ud7-th
2x8gb hyperx ddr3
Dvd writer
Thank you
