I have been having many a problem with my most recent build and was wondering if anyone could give me a few pointers.
First the spec:
Core 2 Duo 3Ghz Processor (from old rig)
OCZ 4GB DDR3 PC3-10666 RAM
3 x GTX 280's in SLI
Asus Striker 2 Extreme Mobo
Cosair 1000w power supply
2 x 74GB Raptors in Raid 0
All Watercooled
I have basically lost my mind and never had any issues with any computer builds in my entire lifetime.
I have proberly installed windows about 10 times now trying all different versions and I'm still having issues.
Currently Im running Vista Enterprise 64bit and it refuses to boot into windows without the windows cd in the drive? I have never seen this before, I have tried changing boot order but nothing works other than putting the windows cd in the drive.
I used to get 30ish FPS solid with 1 card in Crysis now I get 70fps and when people appear it drops to about 10fps where as before it used to drop to 25 at the worse. This is at full res on a 30inch dell everything on very high.
Then I decided to run COD 4 everything on full again and full AA and it runs 200-250+ fps. It almost seems like just crysis ?
On previous attempts It would blue screen loads while trying to play crysis and sometimes just crash in windows, everything is currently at stock speed aswell?
Any help would be great
Thanks
First the spec:
All Watercooled
Thanks
