problems with o2 internet!
3 Jul 2007
Rochdale/whitworth
ok iv just be connected today got the text message saying im redy to use it but
its just keeps disconnecting evey 25 secs then connectin again. Foned o2 and they did some tests and so on then sed they will moniter the line for the next 24 hours. Witch is point less has any one els had this problem and can help me
I had EXACTLY the same problem. Are you using a static IP address by any chance? I was allocated a 'bad block' according to the CS team.
