Problems with PC
29 May 2005
Hey everyone,
hope i've posted this is in the right place.
Im having some problems with my pc that i was hoping someone might be able to help with.
Basically i cant switch the pc on at all. I turn the power on, it starts up for a fraction then switches off.
Ive done all the silly basics like making sure all cables are plugged in properly, ive even changed the motherboard battery thinking that it might help.
The pc is about 4 years old, running on an antec psu.
Any help on what i can try would really be appreciated.
Thanks
Jay
Try each ram module individually just in case you have a faulty stick.
Is there a possibility of testing parts in another system.
ok il give the ram sticks a check first.
Cant check the parts elsewhere, no one else near me has a pc similar to mine, and most have gone to laptops.
