Problems with socket 775 stock heatsink
26 Jan 2006
Hi,
Having trouble installing the stock heatsink... anyone any tips? can get 2 of the clips in but not the others, is weird :-s They won't all clip down at the same time for some reason, all the clips, clip in individually, but not at the same time.
Thanks
They can be a pain in the **** to fit sometimes, make sure the bottom plastic bit goes through the hole as sometimes when I have installed these I catch them on the motherboard and the thing wont clip into place, end up taking the whole thing off and starting again.
You might have to add a lttle force, have torch handy sometimes that helps if you have poor light.
Rob
