Problems with Sun Java.
Caporegime
28 Jun 2007
Tamworth, UK
When I play chess in pogo.com using Sun Java, I get a harsh white noise intermittently. It is the same using any browser (FF, IE7, Safari, Opera) but doesn't do it if I uninstall Sun Java and use the Microsoft VM with IE7.
I use FF for everything now and it needs Sun Java to load Pogo. Anyone else experience this/know a fix?
Thanks,
Jon.
Gillywibble said:
No. I'll try uninstalling & removing any registry entries.
Try CCleaner or RegSeeker to clean up your registry.
Have you checked the Java site for a support base? This could have happened to others before and so a fix might exist.
