Problems with USB mass storage
17 May 2013
West Sussex, UK
Hi, I have a Sandisk Cruzer Blade 8GB that I use in the car for music.
If I plug it into the PC to add music etc, it wont show up. I have to go into device manager and uninstall the mass storage device. I then unplug it, plug it back in, and all is OK. Once I'm done, I eject the device from the taskbar.
If I then plug it back in, I've got to start all over again.
It's never failed in the car.
Any ideas?
You don't say what operating system your using...
If using Windows 8+ try disabling Fast Startup in Control Panel / Power Options / Choose What the Power Buttons Do
See if that makes a difference
I'm running windows 7 64bit, I haven't tried it in another PC. I will try and report back
Posted from Overclockers.co.uk App for Android
