Problems
21 Sep 2005
Leeds
cant get in to safemode on my gf's pc need to run a chkdsk and a fixmbr /r
but it wont let me even get in to the comp even using the os disk is there another way i can run a chkdsk ?
thanks this is really important as i dont rly wonna have to wipe the comp as of yet wonna use that as the last resort
plz help me
Boot from your windows Cd, select the option to run the recovery console (gives a DOS screen), then you can run chkdsk and fixmbr.
thats all good and said but i cant actualy get in using boot cd due to it nearly finishes for me to use it and it blue screens and gives me BAD_POOL_CALLER never seen that before is there away i can do chkdsk n fixmbr without using the disk or been in safemode ?
cheers
