- 29 Nov 2004
- Omnipresent
Hi all,
I'm experiencing problems with folding on my GTX460 using GPU tracker
I'm getting the following error (i can post the whole log if needed?) -
GPU 0 failed to complete a project 6800 WU (UNSTABLE_MACHINE)
As you may have seen, i recently swapped cards between machines, but i'm not sure if that is a red herring? I've never had a problem with the card before and it had been crunching fine since being swapped last week? Then today it starts throwing up this error?
In an effort to resolve this i have updated the nvidia drivers, reinstalled gpu tracker, deleted all work and re-downloaded, and turned it off and on again!!
I'm wondering if there is something lurking in the registry that is referring to the old card which is throwing the client off?
Additionally, it keeps downloading project 6800 wu's, not sure if the fault lies here?
Anywho, if anyone has any pointers they will be most welcomed!
Thanks
Thanks
