Prodigy Build Check
RAMS a bit slow, Haswell have a good memory controller so I personally would be grabbing a 2133MHz or greater kit.
Yea. Read a review recently the Haswell using higher speed actually can increase frame rate for some games by 1-2fps comparing to the 1600MHz memory.
>OP
The BitFenix Spectre 200mm should be changed to a BitFenix Spectre PRO 230mm. I fitted one in Prodigy no problem (though it took a while to figure out which holes to mount it to, as no instruction was provided).
>OP
Seen higher in some games, also seen this for BF3 - http://www.xtremesystems.org/forums...a-(M)-Thread&p=5201211&viewfull=1#post5201211
