- 26 Dec 2013
- 404 Not Found
I have fitted a top mounted 40mm thick rad and 25mm thick fans in the top of my Prodigy. With my GPU block in place I am going to struggle plumbing it in..
As you can see from the pictures its a very tight fit. What would be the best solution to this problem?
I'm thinking I will have to put the 240mm rad up front and change my D5 pump to something smaller, so it will fit between the front rad and motherboard tray.
