- 15 Aug 2006
- Leicester UK
Hi All,
I'm looking at some new high-ish spec PCs for work. I'll be looking to get 3 machines in total for upto £750 each, excluding all peripherals.
Looking around the website, I think the Titan Goliath is the closest to what I'm looking for but I would welcome any further advice. The machines will be used for video editing, video encoding, Photoshop, a little bit of 2D CAD and some fairly complex powerpoint presentations. Usually, more than one of these will be going on at the same time on the same machine. This has to all stay on 32 bit, Windows 7 Ultimate (Volume License).
My questions then are:
Am I looking at the right kind of spec for what I want to do?
Does the overclocked machine I posted above come with a warranty for the CPU even though it's overclocked?
Where can I find comparative benchmark scores for the OD'd i7 920 vs the Standard i7 920?
Do OcUK do any extended warranty?
Is there anything else I need to consider that I haven't mentioned?
Thanks,
Thanks,
