Time for my first build and first mod. Will be a staged build as I need to gather funds to make this into eventually a hard-tubed watercooled rig, but need to replace my current laptop quickly.
It's named as a twist of my own screen name, the altitude and air pressure in which a human can no longer survive without a space suit.
It'll be built as follows:
Stage 1: Modify the case & build a functioning PC
Stage 2: Add graphics cards!
Stage 3: Watercool
Initial Build:
Case: Phanteks Enthoo Evolv ATX
Processor: Intel i7-4790K
Motherboard: Gigabyte Z97X-Gaming G1
RAM: Kingston HyperX 4x 4GB 2400MHz Savage DDR3 Memory
Storage: HyperX Savage 240GB
Cooler: Corsair H80i
PSU: EVGA SuperNova 750W G2
Modding:
Theme will be White Blue & Orange accents
Painting the case white, inside and blue outside.
Painting motherboard heatsinks blue
SSD's painted blue
Radiators and fans will be painted, not sure what colour yet.
Naturally this is all subject to change!
To add in the future:
Graphics Cards: Possibly only a GTX 970 as this should fit my needs.
Extra Storage: An extra SSD, 2TB HDD (brand TBC.)
Cables: Trying to source the individual components to custom make and sleeve them to length.
Watercooling:
1x 360mm thin rad on top
1x 280mm thin rad on the front
D5/DDC Pump
EKWB clear blocks
Big Tube Res
Hard tubing
Pastel Orange coolant.
I've taken a lot of inspiration from some of the fantastic projects on this forum over the last 6 months of researching and I can't wait to get started. Here's my initial plan...
