Day 8
Drilled the holes for the lid.
Drilled and tapped the top angle
The back angle needed some more holes drilled.
Glued the top angle to the front and back sections. That took a lot of fiddling to get just right.
Naked shots. Note the PSU mount has been fixed in place (at last).
While the glue was setting, I marked up the lid for a 120mm fan.
Unfortunatly I dont have a 120mm hole saw. So that gonna have to wait to sort that.
And that brought the day to an end.
This evening I assembled the case. It still needs the side angles glued on and the lid screws will be replaced with countersunk ones. And the switches need to be soldered (need to get some heat shrink oo).
Not much left and I can remove the rest of the protective film and install some hardware.
