Hi all, time for my imaginatively titled Air Cube v2 to get done sorry could not think of a good title so it is a spare of the moment title.
I got the flat bars and angle bars today of the aluminium, I should have the sheets tomorrow. at last woohoo lol i'm a tad excited for my next modding fix.
The flat bars are 20mm wide by 3mm thick / angle bars are 12.7mm x 12.7mm x 1.58mm
the sheets are 1mm thick for components and 1.5mm thick for panels
insert completed project pic here
Here is the new small 2-5mm hss countersink bit I just bought and these are the little m3 countersunk allen head bolts and half nuts, I'm hoping I will not need rivets at all for this so it can all be dismantled easily for painting and further mods.
Here is the main structure I will be making 1st of all which I hope will be strong, probably got over 30 120mm fans in bags lol, so 3 for the front instead of the 200mm fan this time so it will need to be about 30mm wider than planned but that can be a good thing for hdd wire space, 2 for the true, 1 at back and 1 in front of the hdd's.
I'll be swapping all the fans when I can afford it with the akasa apache 120mm fans as they are 57cfm at only 16db and are rated to last 50,000 hours.
I'm going to have my 1st go on a drill press with this project and plan to use it quite a bit, hope it is as good as I imagine it would be, I'll be sure to very carefully do the measuring and marking and it should be fine I hope , lucky my dad is into motorbikes and has done a bit of restoration work on them so he has a few very useful tools to compliment the ones I have bought. He has a powerful air compressor that is outstanding for making a dust clogged pc look like brand new , still yet to get into using quality paint with a paint gun and air brush, annodising seems quite hazardous unless you really know what you are doing but I think it would be my prefered choice or I could just pollish it to a mirror finnish.
I'm very tired from over exercising every day for the past month I'm shattered lol so will start on the project in a couple of days when i'm a bit more sparky as long as the aluminium sheets come tomorrow.
So hopefully I will not bore you all any further and just post pics with as short as possible descriptions whenever I progress a bit further .
Compliments & pointers are very welcome without them the 1st time round I would not have redesigned it better so if you think I'm doing a good job once I have some actual work in progress shots leave a comment .
