Thursday evening
Made a start & I measured & marked the 2m bars ready for cutting.
Friday mid day
Only got all the bars cut to size with a hacksaw with 1 slightly wrong, good thing I bought a little extra for if I mess up made another 1 and here is how it will be going together.
Was really getting stuck into it but was getting aggravated quite easily so I called it a day as I figured I'd end up making a pile of mistakes with not being nice and calm
Saturday morning
Very late start at 15:00 lazy day
overlapped the bottom angle bar pieces and marked the bits that needed to be removed so the angles slot together for a flush connection, hacksaw and file used.
Here is one of the angle ends which I cut and filed.
here is the lowest base loosely fitted together
here is the 1.5mm thick sheet snugly fit inside the frame with little angle bars which will support the corner angle bars, I'm happy with how its going so far but kind of dreading the drilling I'll be doing tomorrow lol, as you can see I'm going to have to get through 3 layers precisely or it will mess up, but I'm hoping to at least get this bottom base complete and bolted together tomorrow.
1 more thing, the camera I'm using olympus fe-170 6mp, I have noticed it is giving a fish bowl look about it as some parts look slightly curved, but the actual bars are definately straight, pretty strange.
