It looks ok from the angle I shot the pics at, other angles don't look so good, well they do but nowhere near perfect anyway
The paint in some areas is a little bitty and rough and for the clear I have used just over a can and half, I hope it looks ok when it has dried and cured a bit, really I should have put more work in to getting it smooth, kind of rushed it a bit like usual, but I'll accept the finish anyway, think I should get someone else to do the paint job in my future mods, I lack the patience and expertise and quality paint and air brush and spray gun for painting, I'm just not all that good at finishing my mods it seems, just must be getting too excited to set it up lol
.The paint in some areas is a little bitty and rough and for the clear I have used just over a can and half, I hope it looks ok when it has dried and cured a bit, really I should have put more work in to getting it smooth, kind of rushed it a bit like usual, but I'll accept the finish anyway, think I should get someone else to do the paint job in my future mods, I lack the patience and expertise and quality paint and air brush and spray gun for painting, I'm just not all that good at finishing my mods it seems, just must be getting too excited to set it up lol
lol.
