The lime green tape on the uprights contrasts well with the blue, in a modern ikea-ish kind of way. Maybe you should start making more furniture!
PK!
, next time I get the urge to mod I might just do that
Update time
Skip to the pictures if you're not interested in the details on what's been done
1200mm high
400mm wide
380mm deep
Weight air cube v2 empty ??? very light but won't be known until I upgrade to a i7 or amd hex core rig or given the speed of new tech these days & my money flow being slow & low maybe something far more awesome once I have enough.
Weight air cube v2 fully loaded ? I'll update soon
weight empty stack ? I'll update soon
weight fully loaded stack ? I'll update soon, it'll be heavy
Since last time where I got the main basic structure done, I have been busy getting the trim supports made.
The front & back of level 2 & 3 I put 1/8" polished angle bars for a support for the various sized flat bars to stop dvd's falling out, I gave the flat bars a simple brushed finish, also put 9mm x 6mm flat bars for a dvd stop & psu slot, put a flat bar with switch mounting holes for turning ps3 fans or xbox fans on/off, upper 1 is for the ps3, lower is for xbox. All the extra trims are put on with araldite rapid steel adhesive, very very strong 2 part adhesive.
Cut solid square aluminium bars to the size of the ps3 with extra for a slope on both sides, cut angles & super glued them perfectly aligned to the ps3 base to keep it easy for putting it on the level how I wanted it, this doesn't void the warranty btw as I can easily remove the bars if needed
, so the ps3 has very good ventalation now above & below so the side vents should be able to take new air in, much better than just having it on my desk, I no longer have to worry about it having a melt down so now I can get really stuck into red dead redemption
I was thinking of cutting solid square bars to size to put in the corners of each level to give even more support but I'm not sure it needs it to be honest, it's very rigid all over, I'll have to think about this.
The braiding could have been done better, I'm a n00b at braiding, but I'm ok with the result, they're out of sight
, the psu wires are folded over & over & wrapped with cellotape to keep them in a compact bunch with a paper clip in the green & black pins to run the fans, the switch cables I chose the lazy route & bought 2 off ebay, 900mm long though so just folded the cable to the length I wanted & wrapped tape around them so no cables interfering with the games/dvd's area, hmmm nintendo wii in the bottom space, hmmm probably not, currently or planned to play games/films, ohhhhh yeah
The xbox wouldn't fit into the level, so it was either refabricate the top piece or cut the rear off so I could slide the top on, I cut the rear off for the time being, after the amount of space left over with the air cube & wanted it all to be a good fit, must be less than 1mm spare above it, the missing rear piece can only be seen from behind so I can live with that.
One problem I've come up against is the floor in my room where I want to have the cpce (Console PC Entertainment) is not flat so I'm going to cut a wooden piece to size, put something underneath the wood at the front so it makes a level surface to keep it on, need to do this asap as it's a bit like the leaning tower of pisa, keep expecting it to collapse all of a sudden, so yeah I need to do this asap
This stack project was something I was not very sure about, mostly needed something to keep me busy for a while & was a bit of a spare of the moment kind of design, but man am I glad I went for it
, I mean I'm sat here & I look to my side & I'm surprised it's me that made it lol
There will hopefully be another update with quality outdoor daylight pictures once I've sanded the front grills to a nice finish & repainted, it'll need it since it'll be taken back down to bare metal, then I believe I can call it a 100% finished for sure this time woohoo
With it being summer & I like to keep a good overclock with nice temps the quiet small fans have a hard time keeping things really cool, so just for summer warm spells I will use a desktop fan on the lowest setting with the top & sides off, the results are better than peak winter & temps barely rise when gaming & pushing the pc hard.
OK I think I've covered everything about what got me from my last update to now so I'll shut the hell up & show a pile of pictures in it's 99% complete state, enjoy
