Project : AlienWhere -56K All Pics < 640x480-
  • Thread starter Thread starter JC
  • Start date Start date
JC
JC
10 Dec 2003
Surrey
Complete
Welcome to my Case and Room Project.
I thought that I would like to put together I thread with all my work in it over the last few months, since building my first PC last november. Some of you may have seen my previous thread but things have changed and I would like to present to you the new thread.
I present the three main areas:
The AlienWhere Case
The Keyboard Mod
My Room
The AlienWhere Case
System Specs
  • Asus A7N8X Deluxe Rev 2 (Bios 1007)
  • AMD "Barton" 2800 XP+ @ 3200
  • Thermalright SLK-800a + Tt Smart FanII
  • Corsair 1GB DDR XMS3200LLPT TwinX (2x512MB) CAS2
  • Hercules Radeon 9800XT 256Mb
  • Twin Seagate Barracuda 7200rpm 120Gbs Raid 0
  • CDRW
  • DVD Drive
  • Creative P580 5.1 Speakers
  • 5 LED Blue Fans
  • 4 Blue/Green Cathodes
  • Antec PlusView 1000AMG
  • Enermax 460W PSU
  • Logitech Keyboard
  • MX500
Build Log
Originally Purchased 1Gb Kingston HyperX 3200 2x 512Mb BH5 from online store
Received 2x256Mb for 2x512Mb Price
Replaced for 2x512Mb
2x512Mb 3200 Did not run 200mhz :(
RMA'd Found Faulty -Out of Stock- Cannot replace :(
Settled for Corsair 1GB DDR XMS3200LLPT TwinX (2x512MB) CAS2 from OCUK
Mod Log
Cut Antec Side Grill from
to fit Alien Grill
Finished Result
and then lit
New Pics
sorry for the blur on that one
Picture Below of My Mirror Flooring
Picture Below of My Mirror Finish PSU
Keyboard Mod
To do the El Wire Keyboard Mod you need the following
**In case it looks confusing This comprises of pics from 2 separate mods, one using 1 kit where the power goes out the left and mine using 2 kits where the power leads come out the right.
Please note I will not take any responsibilty for anything you do to your keyboard following this mod**
  • A Keyboard (Here a logitech)
  • 1 or 2 kits of EL Wire
  • A Screwdriver
  • A Cutting Tool
  • A Sanding tool
  • Glue Gun or Super Glue
To start with I removed the front cover from the logitech and removed all the keys. Use a flat ruler, your finger or a screwdriver to pop them off.
It is then easier if you collect them in groups, say Numberpad on the right, Number Row in this container etc. Makes it much easier to put them back on instead of hunting for each key.
Remeber if you dont have another Keyboard to refer to:
Now is the time to take a photo ;) You dont want to have to guess where each one goes :p
Then get your EL wire and plan out an unstuck route giveing slack on the corners so you know you will have enough room to get round when its stuck on.
Perhaps use a key to hold each corner down.
Then if you dont like the route you can change it or add another kit.
Try to spread it out to cover as much of the keyboard as possible.
Glue gun may come off easier
Then when you are happy procede to glue it down with whaver you have chosen,
i used super glue tho :p
Heres one i prepared earlier:
But we are not there yet, on the logitech I then needed to cut the front panel to allow the EL Wire to go along from one section of the keyboard to another. I did this with a file.
[PIC to come]
I then needed to cut the exit for the Power lead
I did this with a craft knife and then a file.
The Next step may not apply to all but it did to me.
Before Putting all the keys on: see if they will depress fully enough to register. If not, as in my Case:
Pick up your sanding tool and cut all those keys down until they do :--( tiring work.
Get one of these
My Room
In November (now my current room) the spare bedroom looked like this
Lol Im afraid thats the only pic I have of the room, as one doesnt tend to take pics for no reason. And there was a reason and a half for taking a pic of that mess ;) Dont build your computer in your room, use somebody elses :p
Anyway until 4 weeks ago it looked like a neater version of that with computer clutter removed.
Green Carpet as seen in
http://www.firedragon.plus.com/alienwhere/ocukarchive/case black mounts.jpg
That fugly wallpaper ^ and a huge bed that filled the room.
Now 4 weeks later I would like to show you a lot of hardwork (lots of My Dads tbqh) in the making of:
I don't really like the way the blue looks behind the keyboard, it's too uneven. Would be cool if you could make it more even all over or something.
Everything else looks very cool though
Leaving aside the controversial case badges, (which i thought looked fine tbh), youve done a really good job with that case. The keyboard mod isnt quite to my taste, but i do appreciate the work that goes into it - i sure as hell wouldnt want to have to take off and then place back all of those keys :p
Nice spec and room layout too :)
