Project ATOM - Small, Powerful & Probably HOT
Nice pictures thanks. Whats the length of the GPU in there
Posted earlier in this thread, its a Gigabyte V2 OC 5070 Ti measuring in at 261mm and just fits, worlds smallest 5070 Ti, runs great, not overclocked the GPU seems to max out around 76c under load and is quiet.
Thanks mate. It looks a tight fit
Case is designed for upto 260mm with front supplied fans in place, so yep its tight.
Had to remove front fans and mesh to get card in, then re-installed those once it was in place. :)
Was set on a 5070, so very glad Gigabyte released this V2 version, which is basically over 25mm shorter than older card, something Gigabyte have not really promoted, as its the smallest 5070 Ti in existence, so ideal for a smaller build like this. :)
