This was my system prior to my Gigabyte 3080 Gaming OC arriving. This was a quick and dirty loop to get up and running that needed to be reconfigured to accommodate the GPU.
The main problem was the length of the card impacting the reservoir, however with a little creative thinking I was actually able to use the pump casing and bracket as a makeshift anti sag. This resulted in being unable to mount my 360 mm rad in the bottom due to how low the reservoir had to sit, Yet it couldn't be raised any higher as then the GPU wouldn't fit.
The case being so poorly utilized really started to get on my nerves after a while, also how drab it looked started to get on ones nerves. With the side panel on it was pretty dark inside and while that's not the most important thing, I knew I could do better.
I just want to stress I had absolutely no plan for this I was just bored and had some cash to burn
So what happened? These happened!
Stay tuned for part 2! lol
