Front Panel
Remember my front panel plate template I did in post 17. Well I know i said i was going to go with cork or acrylic - well, i went with neither. Cork was way too flimsy and really didn't bode well.
Whilst buying a few bits and bobs in B&Q i came across some ally sheets, 'that will do' was the thought in my head. So i used my template to draw out the shape on the ally sheet, cut the outer shape with a pair of scissors and used my dremel to cut out the inner holes.
Below is the result - about 98% completed. Just need to put some egde channel around the holes and once thats done it will be double sided taped down and some filters will be put in. I wont be screwing it in as there is not enough 'meat' left behind the plate.
I hooked up my psu, connected both fans and it runs perfick
no vibration and pretty silent fans for 12v.
My bad photography dont do it justice IMO, it does look pretty good. Once again its something different rather than better which is what I am trying to achieve.
Im going to do the same for the top panel too. Three holes and they will be off centre as the arc midi as the mounting spaces towards the top left of the case if you look at it from the top.
Thats it for now, slow progress but progress nevertheless. Those 12 hour shifts - urgh.
Oh, managed to flush both rads too so they are good for installation once I have sorted out the top.
Stay Tuned.
