- 1 May 2013
- M28
At least it's not a tacked on afterthought in this racer.
If they can optimize the code we can up the SS so it will look better.Looks excellent, I'm quite fond of PC in VR although the menus can be a little clunky, so if this is VR from the ground up it should be a nice improvement. Graphically though the bottleneck is still going to be the resolution of the HMD so not sure if there will be a huge improvement in that area?
They've certainly optimised something graphically, my 980Ti fans aren't as loud in PC2 now as they are on PC1, even before it's finished. I haven't really kept up with the dev notes this time around so I don't know what they've done.
I'll do a test run with the same track and car and check loads, voltages, temps tonight if you want. Will give a good idea where it's headed.
