Started this build / project 3 years ago never did a proper log so thought i would share pics , and things i have done to make it better
Original Parts / build
changed the cpu cooler to gelid gx7 and installed a his 7850 added a modular power supply 2014
8 channel fan controller added
Started collecting new parts late 2014, first attempt at water cooling
finished the initial cpu loop and added a ocuk gtx 970
still wasn't happy decided to throw more money at it
full water cooling loop is in order i thought
fitted a 45 mm rad to the rear had to mod case a bit to get fittings in
block fitted to 970 installed and loop layout finished
finished job just tinkering with lights to do and case side panel needs modding slightly.
leds off
finally happy with it
leds off
