- 14 May 2012
YOUR BASKET
2 x Asus GeForce GTX Titan 6144MB GDDR5 PCI-Express Graphics Card £799.99 (£1.00)
1 x Asus Rampage IV Extreme Intel X79 (Socket 2011) DDR3 Motherboard £364.99
1 x Corsair Obsidian 900D Super Tower Case £299.99
1 x Corsair AX1200i Digital ATX '80 Plus Platinum' Modular Power Supply (CP-9020008-UK) £264.98
1 x Intel Core i7-3820 3.60GHz (Sandybridge-E) Socket LGA2011 Processor - Retail £259.99
1 x Asus ROG Xonar Phoebus 7.1 PCI-E Soundcard £185.98
2 x Corsair Dominator 16GB (4x4GB) PC3-14900C9 1866MHz Dual/Quad Channel Kit (CMP16GX3M4X1866C9) **SPECIAL** £139.99 (£279.98)
1 x EK Water Blocks EK-FB KIT SR-X - Acetal+Nickel £109.98
2 x EK Water Blocks EK-FC Titan - Nickel Full Cover Waterblock £79.99 (£159.98)
2 x XSPC EX480 120mm Radiator - Black £66.95 (£133.90)
1 x EK Water Blocks EK-Supremacy - Acetal + Nickel £56.99
1 x XSPC EX240 Crossflow Radiator £44.99
1 x XSPC EX140 Single Fan Radiator £39.95
2 x EK Water Blocks EK-RAM Monarch X4 - Acetal+Nickel CSQ £34.99 (£69.98)
2 x EK Water Blocks EK-FC Titan Backplate - Black £24.95 (£49.90)
Total : £3,941.78 (includes shipping : £16.85).
10 Noctua NF-F12 Fans
Plus Bitspower Crystal Link fittings (unknown quantity)
2 Aquacomputer D5 USB / Aquabus Pumps
Aqua Computer Aquaero 5 LT USB Fan-Controller
Either Koolance RP-452X2 (rev 2) Reservoir
or
2 Bitspower 250mm Tube Reservoirs
Mayhem's Coolant (either pastel white + dye, or water + dye)
2 Corsair Force 3 (60GB) HDD's
1 2TB WD HDD
and a couple of other HDD's
I think that's everything.
Mods:
MDPC-X Sleeving
Rit Dye (for the Fans)
Again; I think that's it
I need the case (7th June)
I'm transferring everything except the res, graphics card blocks, pumps, and the crystal link from my current case (Thermaltake Level 10GT) As it doesn't have the space for 4 Rads + everything else.
However I will post some shots of my current case; Hopefully the sleeves will turn up soon so that I can start modding my cables.
But before I start, I have a few questions!
What colours should I choose? Black is certainally going to feature I've seen some really cool looking cabling in:
Black / White / Violet
(24 pin was 4 Black, 4 Violet, 8 White, 4 Violet, 4 Black)
Black / Red / White
Or another option?
Assuming a 3 colour cabling I'd use the other 2 colours other than black for the coolant.
(If i was using white i'd use Pastel coolant)
or
1 2TB WD HDD
Mods:
MDPC-X Sleeving
Black / Red / White
Or another option?
