Project Corsus Thea
13 Jul 2012
Greetings all!
This is a small account of the trials and tribulations of my newest build. It is not going to be nearly as good or as complicated as some of the fantastic projects i have spent half the weekend reading about on these forums! It is however going to be mine and she will evolve as inspiration strikes me and as funds allow ;)
I finally decided to build a new rig as one of my family members was looking for a reasonably powerful desktop for photograph manipulation. This was just one more excuse I needed to 'give' my old rig away, paving the way for a shiny new one :D
As you can see from this picture the last one I built was a tad messy, it still did the job though! (I am stealing a OCZ Vertex II, 128Gb SSD from this comp. Was going to use it as a boot drive, not sure if that is a good idea though. What speeds does the sabretooth utilize?)
Here are the components I have already purchased;
YOUR BASKET
1 x Asus GeForce GTX 670 DirectCU II 2048MB GDDR5 PCI-Express Graphics Card £329.99
1 x Asus Z77 Sabertooth Intel Z77 (Socket 1155) DDR3 Motherboard £181.99
1 x Intel Core i5-3570K 3.40GHz (Ivybridge) Socket LGA1155 Processor (77W) - OEM £167.99
1 x Crucial RealSSD M4 256GB 2.5" SATA 6Gb/s Solid State Hard Drive (CT256M4SSD2) £152.99
1 x Corsair Graphite 600T Midi Tower Case - Limited Edition White £145.99
1 x Corsair HX 850W ATX Modular SLI Compliant Power Supply (CMPSU-850HXUK) £121.99
1 x Antec Kúhler H2O 920 High Performance Liquid CPU Cooler (LGA775/LGA1155/LGA1156/LGA1366/AM2/AM2+/AM2+/AM3+) £84.98
1 x Asus Xonar D2X 7.1 PCI-E Sound Card £79.99
1 x Corsair Vengeance 8GB (2x4GB) DDR3 PC3-12800C8 1600MHz Dual Channel Kit (CMZ8GX3M2A1600C8) £59.99
1 x Pioneer 24x Internal DVR-S19LBK DVD Rewriter including Labelflash - Retail £20.99
1 x Akasa AK-188-WH 2 x 12" Cold Cathode - White £11.99
Total : £1,376.58 (includes shipping : £14.75).
I was very pleased and surprised to find my free Haribo (cheers OcUk) as well as a strange looking chinchilla in my package...
I was over the moon to finally receive my goodies having waited all week for a day off to build it :D All the bits looked fantastic though i was shocked to find the OEM CPU in a half opened wee box!
Sadly i was sent the wrong case so that scuppered my planned marathon weekend of BF3. I am glad it was nice weather however so i was out and about enjoying the weather instead :cool:
Its late now, more pics to come, thanks for reading!
As promised here is an update :)
I had a very frustrating start to my new rig. I had all the bits but because the case was the wrong one i couldn't really do anything!
I did ofc open all the boxes and stare in wonder at all the shiny bits, even the boring DVD drive held a slight wonder for me - how quiet would it be and how fast would it install windows? (very loud and very quickly it transpired)
Thankfully we had nice weather over the weekend so i managed to keep myself busy around the doors during the day. In the evening i sated my building urges by tinkering around; i dressed the mo-bo ready for fitting and i test assembled the CPU cooler.
I was very impressed by the build quality of the mo-bo. It is rigid and heavy, living up to the 'military' credentials that it claims. The only thing that perplexed me was the two 35mm fans that you have to install yourself. I don't know why they give you this little bit of DIY to do, i for one found it a welcome distraction :D
Arnie CPU Kuhler...
Looking from underside...
Processor put to bed...
Dressed MoBo...
Thanks for reading :)
When the case arrived on Monday i was over the moon, i managed to calm myself and still take some photo's though :)
I took some better ones and then dropped the camera. Some of my pictures have now been corrupted, stoopid technology! The camera now won't see the laptop to download photo's either. Thankfully the lappy has a card reader, adapt and overcome ;)
I had a nice sunshine shot of the case to show it off, unfortunately it is fubar'd...
Instead, here is the inside;
The build quality again is fantastic. It is a lot larger than i thought it would be. I was used to the Antec lanboy mini case so this is a massive step up. There are cables galore but everything is nicely labelled up so there is no need for instructions. The case is very versatile, there are many different configurations you can have, just like most modern enthusiast cases. The bendy hard disk caddies are a brilliant innovation, so efficient and secure too. The PSU mounting bracket is quick and easy to use and holds it firmly, I tried to move it once tightened and there was no give. This case has so many nifty features that made the build a lot faster and easier.
As always there are a few niggles. The first is the USB3 integral port does not have a mobo connector. It instead terminates with a proper USB port so you have to take it outside your case and plug it into the back of your mobo. There is a cut out on one of the rear card blanks that you can feed it through, it is far from ideal though. Another would be some scratches on the window of the case and the last one would be the integral fan controller has weird connections to plug your fans into (i have yet to work them out).
More to follow tomorrow, gotta catch up on sleep, got 3.5 hours last night before my ears were assaulted by the alarm :(
Good night all o/
Thanks Mr 25!
Ok, after the PSU was in i installed the mobo...
Post mobo fit i started on the CPU cooler. I was very surprised by the size of it! The rad is very deep on its own, then with two fans it is huge. The cooler was well designed, the only part i wasn't entirely comfortable with was the two pads at the back. They were there to protect the board i am sure, they just sat on a couple of diodes. This is down to Asus though and not Antec. Unfortunately i had to remove the rad and fans again as i failed to connect up the ATX 8 pin power connector which was entirely obscured by the rad assembly - i was rushing :o
One thing i did need to do out of the ordinary was remove the rubber anti-vib mounts from the rear fan mount. This was to enable the supplied screws from the cooler to get enough purchase on the rad (through first fan). The rubber mounts just took up a few too many threads preventing a strong install.
After rectifying this i put the hard drives in. The crucial SSD was tiny, too small for the drive caddies so i will need to bungy it in. I inverted one of the caddies and this made a perfect little niche for it to sit. The Vertex slotted in beautifully. As i mentioned before, this case is a dream to work with as it has a lot of clever design features that help and speed up building.
After the hard disks and DVD drive it was time for the mobo connections and then onto fitting the cards and RAM. I took plenty of time tidying the cables away. I think it payed off but i am very biased :)
After further tweeks and the first power on i took some more photo's...
Then with the case on...
From the front...
And the final arty shot :D
And that was my build! I thoroughly enjoyed this project. There are still a few bits to do;
  • Cut hole for light switch
  • Fit another 670GTX
  • Polish out scratches on window (or attempt full window mod)
  • Overclock (dependant on CPU cooler efficiency)
  • Full water cooled system, subject to funding and requirement
  • Fix Vertex drive (it is not displayed in My Computer)
However, that is me for the time being. I am enjoying the system and being able to kill everyone on BF3 :p
Take care all, thank you all very much for all your info and advice!
Shalom
tried going into drive management and formatting the vertex, either that or i think its called achronis disk quite to force initalize and format if its not bricked :)
otherwise send it back on warrenty :)
Hi,
not on topic but, do you have any new threads planned?
Thanks
Bakht
Very nice! Would be improved a lot if you added some braided extenders though IMO for the 24pin, 8pin and graphics card.
