3 Sep 2011 at 20:42 #21 skyripper skyripper Associate Joined 19 Jul 2011 Posts 2,368 Awesome radioactive green! Like it.
3 Sep 2011 at 20:53 #22 Sgt Tackleberry Sgt Tackleberry Associate Joined 28 Oct 2010 Posts 2,446 Location Colchester Love the green and black .. What temps are you getting?.
3 Sep 2011 at 23:18 #23 fireisdangerous fireisdangerous Associate OP Joined 24 Sep 2008 Posts 1,161 Location St. Neots, cambs Jeci said: Bang tidy! Click to expand... Thanks a lot
3 Sep 2011 at 23:18 #24 fireisdangerous fireisdangerous Associate OP Joined 24 Sep 2008 Posts 1,161 Location St. Neots, cambs Krony said: Stunning Click to expand... glad you like it
3 Sep 2011 at 23:19 #25 fireisdangerous fireisdangerous Associate OP Joined 24 Sep 2008 Posts 1,161 Location St. Neots, cambs KiiYzOo said: awesome what did you do to get the uv in the pics? Click to expand... cheers, I used a tripod and night mode on my camera. Think i need to get some more uv lights
3 Sep 2011 at 23:24 #26 fireisdangerous fireisdangerous Associate OP Joined 24 Sep 2008 Posts 1,161 Location St. Neots, cambs Sgt Tackleberry said: Love the green and black .. What temps are you getting?. Click to expand... Thanks a lot. My i5 2500k stock speeds with the fans set to the lowest @ idle is running at 33'c and my gtx 570 @ stock speeds is also at 33'c. I haven't overlooked either yet since I got my replacement board but previous i got it clocked to 4.5 so will aim to do the same again
3 Sep 2011 at 23:53 #27 alex2k10 alex2k10 Associate Joined 28 Nov 2010 Posts 193 Nice work I like the fact it's all black and stealth and then there is just an acid green connecting it all soooooo good.
5 Sep 2011 at 22:12 #28 fireisdangerous fireisdangerous Associate OP Joined 24 Sep 2008 Posts 1,161 Location St. Neots, cambs alex2k10 said: Nice work I like the fact it's all black and stealth and then there is just an acid green connecting it all soooooo good. Click to expand... Thanks A lot glad you like it
5 Sep 2011 at 22:17 #29 KiiYzOo KiiYzOo Soldato Joined 2 Jan 2011 Posts 6,150 Location Edinburgh, Scotland I need more uv than you do!
5 Sep 2011 at 22:32 #30 haddows101 haddows101 Associate Joined 28 Aug 2011 Posts 123 Location Glasgow, Scotland reminds me of being on the waltzers you should smile next to it n see if your pearly whites go blue lookin good
5 Sep 2011 at 23:15 #31 Kurisu Makise Kurisu Makise Soldato Joined 1 Dec 2009 Posts 2,815 Location Staffordshire that green colour coolant is really nice iv got uv green watercooling in my rig but when i use uv cathodes on it it turns turqouise need to get it all re done awesome job anyway
