I hadn't even noticed that they'd given you the Noctua GPU! And on a second look it actually does look very good and cohesive (a part of me does love the brown/beige, maybe just cos I'm nostalgic to an era when motherboards were objectively ugly and everything was function>form - like huge exposed slabs of copperI actually requested the brown lol! They also gave me 6 Chromax fans which i used in this build too. I really wanted to try their new 140mm G2 fans so decided to mix and match abit! Plus they're all getting reused in another build very shortly. Nothing goes to waste!
Noctua has been very generous and supportive, they basically gave me everything i asked for so i can use them across multiple builds including the RTX 3070 Noctua GPU shown here.
)!Sounds like you need to take a drill to the case and fix that stupid vertical mount issue. HAVN won't learn from their mistakes otherwise.
I hadn't even noticed that they'd given you the Noctua GPU! And on a second look it actually does look very good and cohesive (a part of me does love the brown/beige, maybe just cos I'm nostalgic to an era when motherboards were objectively ugly and everything was function>form - like huge exposed slabs of copper)!
A friend had a GPU many years back with a crappy cooler, removed the shroud strapped a couple of brown noctuas to the heatsink, looked pretty badass!
Numpty is right about your abilities - your builds are always fantastic and I always look forward to seeing them coming to fruition!
) on the new addition
