HEART OF OBSIDIAN
Hi all,
After completing my last water-cooled build I said to myself I wouldn’t do it again, its just not worth it. Difficulties upgrading, excessive cost, negligible performance benefit, loads of effort if something goes wrong etc. etc.
So here I am, doing another water-cooled build.
Preamble
Before I start id like to ask that if anybody is able to help with respect to anodising, 3D printing, or CNC then your assistance would be greatly appreciated; please send trust. Also, I would really like a logo or banner for the project but my artistic skills are verging on appalling. If anybody feels like they would want to do this in their free time then let me know. Thanks
Objectives
This time I have a couple of criteria that I wish to keep to:
1. Use 120mm fans
I found that 140mm fans are worse than their 120mm counterparts despite their larger area. Pressure especially suffers.
2. Stick with thin radiators
Fin density and area seem much more important than thickness so im going to stay as thin as I can.
3. Silence
This has always been a priority for me as the main benefit of watercooling.
4. Customise
I have a couple of ideas that I wish to implement which you’ll find interesting I hope.
Coming From
This was my first watercooled build:
The Second (and most recent) water-cooled build was as per the following list (everybody loves lists right?)
1. Corsair 750D
2. I7 3770k
3. MSI Z77 Mpower
4. XSPC Raystorm CPU Block
5. Alphacool NexXxos 60 x 280mm (2x140)
6. Alphacool NexXxos 45 x 420mm (3x140)
7. Silverstone Air Penetrator fans x 6
8. XSPC Photon- Glass Reservoir
9. D5 Pump
10. Corsair 850W AX PSU
11. Samsung 840 EVO 500GB
During one the busiest parts of my degree, while designing a hydrogen fuel cell, my ‘wonderful’ MSI motherboard decided to catch on fire.
(see details here: http://forums.overclockers.co.uk/showthread.php?t=18651440)
As a result, I went back to basics and am currently looking at this beauty of a rig:
Complete with loads of dust…
..and excellent cable management.
In addition, I seem to have an unrecoverable CPU issue related to WHEA errors. (more info here: http://forums.overclockers.co.uk/showthread.php?t=18669307) This is probably due to me being a cheapskate and buying a 2nd hand 3770k from an auction site. Big mistake, won’t do it again.
I have not decided if I am going to going for a new CPU and motherboard now or if I’m going to wait. I think I need to do it though because I’m getting crashes and its getting on my nerves somewhat.
The Concept
The new build will be base around my 750D but I have a couple of ideas I would like to implement.
Idea 1
The stock side window on most cases, the 750D included, is very soft plastic. It scratches easily and is a dust magnet. I would like to have a toughened glass window. I have some experience designing so I have drawn up what I plan to do.
I plan to accomplish this using some 3D printed plastic blocks that will pull the glass toward some 6mm thick foam tape that will be bonded around the original window opening. The tabs used to hold the original plastic in place will be cut off with a Dremel and the small marks painted black.
Idea 2
The XSPC Raystorm block that I own has two issues that I want to correct.
The first is that the text on the top of the block limits how it can be fitted to the CPU (assuming you don’t want the text upside down) To solve this I want to get the top 1mm milled off the top. I can’t see this having any effect other than removing the text. The inlet will be marked with a small hole next to it.
The second is that the clamp is made from clear plastic that is quite flexible as it gets warm. Clearly they did this to get the lighting effect that some love. I want to solve this by replacing the two top pieces with a single anodised aluminium block with the profile water jet cut.
Idea 3
This is actually something I came up with quite some time ago, before similar things started appearing with computer cases, but I need a new version to fit a 120mm fan size.
Conclusion to First Post
This is what the general scope of the build looks like at the moment. It is very much a work in progress and will keep updates rolling as I continue.
Well it’s taken me quite some time to write all that so I will leave it at that for now. Again, if anybody is able to help with any form of manufacturing process please ‘trust’ me a message.
touch wood..
