Project: IRON MAN MK8
2 May 2015
Scotland
Project: Iron Man: Mark 8 (COMPLETE)
So.. been working on this for a while, taking longer than predicted due to bad weather.
Specs:
i7 4790k @ 4.9Ghz
16GB Avexir Blitz 1.1 Yellow 4x4GB 1600Mhz
Maximus VI Formula
Titan X
Custom waterloop
2x 240GB SSD's
1x 1TB HDD
Dark Power Pro 11 850w 80+ platinum
Proudly sponsored by
be quiet!
check out their product range here ''be quiet!"
Avexir
Check out their product range HERE
Idea:
helagaks-iron-man-3-mark-8-42-image.jpg-145949d1361857365
So here's a run up of all that's been done so far.
I got bored and decided my current case was nice but not as crazy as myself. (Current Build here)
So the outcome was near £700 in parts and a hell of a lot of time.
Started with my good old Aerocool Strike-X Air case
Decided okay lets be honest... it's bland in black and red.. it needs more POWER!!
So i striped it appart
time to prime the case for a re-spray and kind of liked it in white
NO NO NO!! I'm not going white again. So gold it is.
Okay so first coat of gold is on. Will need to hold off until tomorrow before i can get more gold and hopefully better weather.
Here's a sneaky peak at what it looks like toinight with it's single coat and a sneaky peak at what i'm going to be doing next :D
It's far from finished, custom made arc reactor is on it's way, along side a nice custom waterloop for the build and a titan X which will be re-sprayed as soon as i get my hands on it.
Update: 05/06/2015
Custom arc reactor arrived along side the new coolant.
Coolant:
Motherboard and ram re-painted for the new case
Out for it's final coats
Paint is done, it's now time to add some decals and effects :)
Paint is done, now just waiting for my custom loop to arrive and my titan x.
So far the Mobo and RAM is ready, Waiting for the new loop + Titan X to arrive before i crack on and get all the internals done and finished.
Should be an update on tuesday :)
Short teaser video
I did wonder what you meant about your TX not loooking the same soon, now I know with this project log.
I like a bit of gold, I'm also keen to see this custom arc reactor.
Subbed
Hopefully the weather clears up tonight and i can get the second coat done and maybe some components done. Just hoping that the rain stops :)
The Arc Reactor is awesome... who made it?
The new ASRock G10 Router wouldn't look out of place next to this.
http://www.asrock.com/news/index.asp?id=2801
Guy we found on ebay makes hands and helmets for a few superheroes.
Also does his own arc reactors, war machine's red reactor too.
Not a bad looking router. Shame my router is in a different room. don't fancy running a cable through the house haha
