Right then, this a log for the PC i've just built for Gaming/Blu-Rays/Music Production. Its an IB-based build, with the main goals being -
To be made of newer technologies (lower nm parts) when possible,
To be quiet but not warm in use, and
To be powerful and reasonably power effecient.
Main specs of the machine are:
Antec Lanboy Air
Intel i5 3570K
Asus Z77 Sabertooth
MSI R7870 TFIII
Samsung 30nm DDR3 RAM
Corsair AX750
OCZ Vertex 3 60GB
WD Black 500GB
Before I actually show the pictures of the new machine, i'll show you where i'm coming from (other than my MBP from 2009)...
EDIT: Got it running again, and its an Athlon XP 2600+ at 1.97 GHz with a Radeon 9600 Pro. Built between 2003-04 and re-cased and given a better power supply a year and a bit ago. Has trouble running YouTube video if its anything above 240p!
Now, to the system i'm now building.
Most of the parts were bought (including the case fans to replace the stock ones) specifically so that they would be quiet... except for the speakers of course
The reason for the add-in USB3 card is that the LBA hasn't got an internal header for it.
Antec Lanboy Air
Intel i5 3570K
Asus Z77 Sabertooth
MSI R7870 TFIII
Corsair AX750
OCZ Vertex 3 60GB
WD Black 500GB
