- 10 Dec 2005
PICS IN POST #15 AND #48
OH HEY GUYS,
Decided to jump into i7 and finally put my PC under water. Also switching from ATI to Nvidia. I guess I just caught the unrelenting upgrade-bug from working in tech at OcUK
Old PC Specs:
q9650 @ 3.6ghz (Titan Fenrir)
Asus Rampage Formula
4GB (2x2gb) Xms2 800mhz
Sapphire 4870x2
Corsair TX650w
Samsung Spinpoint 320gb (Windows install and storage)
Antec 902, 3 Red akasa fans
My old antec was totally neglected and instead of cleaning up and re-cable managing my PC I decided I really did need to upgrade anyway. And I just waded in.
Current Spec:
EK Supreme LT Nickel Plexi - i7 970 @ 4ghz, 1.328v
Gigabyte X58-USB3. Budget board but overclocks just the same as the UD5
6GB (3x2gb) Corsair Dominator @ 1600mhz
Zotac 460 /w Nickel Acetal EK waterblock @ 900core clock, 1087 core voltage, 1800 Shader Clock
Samsung Spinpoint f1 1TB (storage)
Crucial 64GB SSD (windows install)
Black Ice SR1 360 rad /w 3x120mm Xigmatek Crystals (Red LED) All running on fan voltage reducer cables
Corsair Professional Series AX750w (Braiding is extremely nice, althought I have PCI-E and 24pin nzxt pre braided extensions now)
XSPC 750ml Bay/res
3/8" Masterkleeer Clear tubing
Fluid XP+ Eco Earth Clear (With added candy red Mayhem dye)
CoolerMaster HAF X
Just got home from work with my fresh new build. Many thanks to rjkoneill and NathWraith for helping me with the spec/build.
Will post pics and update the thread in a lot more detail soon
Just thought I'd tease you all haha! Will also post temps whilst stress testing etc etc.
Really pleased with the final outcome and I hope you guys will be too, it's sleek.
OH HEY GUYS,
Old PC Specs:
Sapphire 4870x2
Corsair TX650w
Current Spec:
XSPC 750ml Bay/res
CoolerMaster HAF X
Just thought I'd tease you all haha! Will also post temps whilst stress testing etc etc. Really pleased with the final outcome and I hope you guys will be too, it's sleek.
Got a bit of case 'editing' to show you guys too, thanks to Rjkoneill
