I take it that the machine is computer controlled, and it's going to make several cuts?
If all goes well its going to do the whole lot in a single cut.
Electricity put through the wire does the cutting?
Curious how you cut something that's away/not connected
To the edge?
Again am assuming the wires connected at both ends
To the machine?
So does it drill/cut a "pilot hole"
Then the wires fed through the hole
Then reconnected to the machine?
Then it does the cut?
ThanksCorrect
Yes you either drill a pilot hole or cut from the edge, the machine then self-threads the wire through.
Ah... that makes more sense, I was thinking it was a bit of unobtainium wire reciprocating at ridiculous frequencies.... so it's like a laser CNC but with the wire acting as the laser?? (as in, the medium for the enegy to travel through?)Correct
This looks super interesting, get a move on
That's some serious throughput, will that be push pull? 16x140 fans?
Peter?You know what makes wire cutters amazing.
This.
Just this.
