Great build and thanks for sharing. Looks huge and we'll done with the planning and execution.
Thanks, as I said I just wanted to rule out as many issues in the early stages as possible
cwgk91 said:
Looks amazing, cool to see a scratch built case. Its enormous!.
Thanks, I've never had the confidence or a design I felt that could work, until now, based on test build I did last year. It seemed fitting to go for it.
So then a long overdue update for you guys. Apologies!
I've made logs in the past but I wanted to do go the extra mile this time around. Sometimes a picture can't show and emphasize where you going, or what you did. For this reason I made the decision to add a VLOG to coincide with this log.
I will say, at this point the videos are raw, no flashy editing or glamour shots to show of course. It's just me chatting about the build and the end goal. Future videos will be shorter and more focused
Feel free to have a watch if you wish
It's been a slow month but progress is starting to take shape now. First thing I ordered was
http://www.overclockers.co.uk/showproduct.php?prodid=WC-180-XS
It was on “deal for today” I believe. I didn’t strictly need it but at the price it would be rude not too.
My first thing to tackle was the first mid plate that the motherboard will mount too. The weld points needed some mass filing, to allow it sit neatly.
I also test fitted the bottom side section, I've yet to cut the two SSD Windows.
MK 1 side by with MKII
The side effect of taking the middle section in and out, filing and such caused some damage at the cases weld points here. I will patch them up before paint of course
I lost a fair amount time with the start of the world cup too, and complaining about the amount of crisps you don’t get in a so called extra fill pack
A nice package came from CoolerMaster arrived.
I'm absolutely thrilled to have their support. The PSU is perfect managing the cables in the build. The Jetflow fans with White LED's will add some nice lighting effects and epic airflow too
I will add some shots of the included parts, cables adaptors and such. I'll be honest I was just too keen to test fit everything!
Tested fitting the PSU and prayed the screw holes lined up
The Jetflows fitted for mock up, blurry motherboard????
As said above, I will add some more pics of the Fans and the PSU Soon
I’m thinking about using something like the NZXT Grid to manage all the cable at one central point in the mid chamber Time will tell
Adding cable routes for the Fan cables was done with a drill and file
Still rough at the moment
I had another package arrive that allow me to move forward significantly also
Again I can't express my gratitude enough to MSI UK for their support.
I will be Working with Gaming 7 Z97 Motherboard and 270X Gaming edition GPU. Do keep In mind what I said at the start of the thread. This was never meant to be a power house. I had always been on the fence to add a GPU with block into the loop or not. I've decided at this point in time not to do that. The loop design however allows me to implement it with ease in the future. Again the desire to get everything in their, got the better of me, so more images to follow soon
Same image from earlier, no need to hide the Board and GPU now
With the parts now here I could crack on and add the mounts for the motherboard
With help from my assistant of course
It made sense to incorporate some “MSI Gaming” theme touches into the build. The first thing I wanted to add was something to the bottom plate around the I/O area. Using the MSI dragon I took a sheet of 3mm acrylic and attempted to make the tail. Results aren't bad considering it was all done by hand and many, many, many hours of sanding and filing went into it!
The process was rather unothordox but kept me busy haha
Lots of mess
and so the sanding begins
and the tail fins
Finally the reservoirs, again unorthodox approach! I have two 50cm versions here to hand, from a retired build. Scratched up and of no real uses. I will be using the 25cm version in due course, so I cut one in half to allow me to mock them up
On top of this I've had a random idea to bring in the MSI dragon claws and well. You’ll see....Using a clamp, the res and heat gun I made this.
I added some white paper, just to aid with separating the colours. The real issue is the scale of the tail and hands, to me don’t feel right, so we’ll see how I goes.
Lastly A good friend of mine supplied with me 10x1m lengths of PETG tubing, in short it’s much more resilient then generic tubing! Again more details to follow. Thanks Dave!!!
So that's where I'm at guys, lots of polishing and edges to clean up. 30th birthday on Friday, A few delivery s due this week or next and then I will be placing the order for the projected 51 fittings.
Till next time, thanks for reading
