Test Mounting of the Waterblocks, and modding the flipped GPU.
Allright, got a lot of work done last few days. Test mounted the blocks to see how it looked best,
then flipped the gpu, bend some acrylic sheets to act like supporters for the gpu, and added some velcro tape to hold it in place.
after that, it was time to figure out how i wanted the cut in the case and pci slot cover to be.
Then after the cut i saw i cut too big of a hole, but still its okay
I also was thinking a lot about the pump placement, if i wanted it next to the 120mm rad, mounted in the back at the mobo tray, or where to put it for the best looks..
Then i thought maybe i could make another acrylic piece bended in the angle of the GPU, so that the Pump actually is tilted in same angle as the GPu, and i must say it's got the look i was hoping for
Also cut out a hole for the LCD temperature display..
But still awaiting the final piece from Parvum, so maybe i will change it later or redo it,
but for now it works out great i think
I also drilled holes for the reservoir mount, and shot a few pics with everything in its place, and also with the window on to see how it looked
So what do you think guys ? .. next up will probably be installing fittings and tubing and figuring out the loop
