Great job on the IO panel - looks very neat. Such nice cases.
Are you planning to keep the apple logo or get rid of it?
Oooooo updates!!! How much extra space on the bottom is there?? (well how thick is the bottom of the case before you consider cutting it??)
Do the front and back fans work together to make the bottom of the case a decent wind tunnel effect??
Ahhhh, well if its just the cage and not the actual case I guess it would be a better way to orientate the heat sink as it does look like it would be more effective to disperse heat (and it follows the set up the real mac pro's have too).
Looking sweet either way!![]()
