i really like those graphics backplates, what have you fixed them to the cards with?
Hi rjkoneill, just double sided tape as Scougar mentioned..
I think he said double sided sticky tape/pads earlier in the thread.
Thanks Scougar
In that picture with the PSU it really pushes the look. You should do the lower fans in the same colour to match the lower part of this amazing build. It would so fit the weathered and perfectly done work.
Definitely have some plans to finish of the fans..
