- 10 Jan 2009
- Now live in Scotland !
This over the next couple of months is going to be my first ever watercooled gaming rig .
components
MSI Godlike X99A
Intel 5960x
2 x EVGA 980ti SC
Avexir Blitz Original Red 16GB (4x4GB) DDR4 PC4-24000C15 3000MHz Quad Channel Memory Kit - Red Light
1TB Samsung 850 EVO
2TB SSHD
2TB Green
4TB Green
EVGA Supernova 1600w Platinum
Corsair 900D Case
Cablemods Red/Black custom cables
lots of Cold Zero goodies, shelving back plates ,mobo plates, and custom MSI printed top and side Grills & Custom SSD MSI plates (and gloss back perspex)
2 x Large MSI badges custom
MSI Gaming Dragon SLI bridge Long with illumination .
Watercooling
EK DDC 3.2 dual pump
EK Water Blocks EK-Dual DDC X-RES Link CSQ - Add-On
Ek Titan x water blocks x 2
EK FC Terminal DUAL Parallel
EK RES X3 250 Reservoir
Bitspower Godlike Full Water cover block
EK Water Blocks EK-CoolStream PE 480 (Quad)
EK Waterblocks EK-Coolstream PE 120 (single)
Phobya G-Changer 480 V.2 - Full Copper
EK black 12mm compression fittings x 20
EK Water Blocks EK-AF Pass-Through G1/4 - Black x 4
EK Water Blocks EK-FC Titan X Backplate - Black x 2
3 meters 12mm EK Hardline Tubing 6x 50cm
Aqua Computer Aquaero 6 XT - with Black faceplate
Aqua Computer Farbwerk - bluetooth and holding plate -Black
Aqua Computer 2 x1m RGB LED's with 4x leads .
EK Y-Split 2-Fan PWM 10cm x1
Monsoon Hardline Pro Bender Kit 3/8 x 1/2 (13mm) - Value Bundle
Thermaltake RIING 12 Red LED FANS x 8
30cm AKASA AK-CBFA01-30 4 Pin to 4 Pin PWM fan extension cable
EK Y-splitter 2-fan PWM 10 xm
60cm Phobya Y-Cable 3Pin Molex to 4x 3Pin Molex - black x 2
FOR DRAIN
Aqua Computer Ball Valve Female Thread G 1/4 without Fittings
Alpha Cool Connect T-piece Black x1
EK Water Blocks EK-ACF Fitting 10-13mm - Black x1
EK Water Blocks EK-CSQ Adapter 45° G14 Black Nickel x 5
XSPC G14" Male to Female Rotary Fitting (Chrome) x 2
XSPC G14" 10mm Male to Male Fitting (Chrome) x3
Mayhems Ultra Clear Watercooling Tubing (38 - 12) 10-13mm
EK Blood Red ready mixed 1ltr
Extra 100ml EK Blood Red concentrate .
going to be exciting over the next month.
Not sure on names yet of the actual build .
Still watiting on a lot of stuff to turn up , im now down to 16GB of ram due to selling 16GB to a friend to fund for other stuff as funding was running low , i have a bit left just in case of needing more fittings as i wont know what bends i will be doing as i would like to have most bends in the actual tubings .
I have now got my eye on this ram .
https://www.overclockers.co.uk/showproduct.php?prodid=MY-122-AR&groupid=701&catid=8&subcat=2556 X2 as i would like all dim slots occupied and would lookamazing with 8x4GB 2x16gb kits , but im not sure if this board will take the 3600MHZ ram
components
MSI Godlike X99A
Intel 5960x
2 x EVGA 980ti SC
1TB Samsung 850 EVO
2TB SSHD
2TB Green
4TB Green
Corsair 900D Case
Watercooling
FOR DRAIN
