Project ネルフ NERV (Picture Heavy.)
Although I dont understand what "Nerv" is, i like how youve thought out the whole build to incorporate it into every aspect of the design - good work!
That's a sweet looking Evangelion based build!
Maybe you should try an EVA 02 colour scheme to match Asuka in the "entry plug" ;).
That's a very ambitious build you have going there, I'm not sure I would like having a massive case like the 800D and then sticking two radiators running parallel on the top I would have perffered (if it were my build) to have kept it all inside. Run a 360 along the top and 240 on the bottom and a single at the back.
It seems your pretty confidant with handling this sort of stuff, I done a full water build earlier this year and while it was much harder then a normal build I don't regret it.
I suggest you have a good look through this thread it's the most amazing custom build I've ever seen the guy really goes to town on it. Granted he's not using a 800D but there's some ideas in there which I think you could use such as how he handles the cabling and the wiring from the PSU (the Li Lian PC-50R is not a great case for cable management). In fact it was this thread that inspired me to do my custom water cooled PC.
Looks like fun mate, You weren't intending on running WC thru the res with Asuka in it were you? The water additives may react with the plastic/paint.
looks like its gonna be immense :)
Am I missing something.... one loop for the cpu which is a corsair sealed unit, and a custom loop for the gpus. That seems like cooling overkill to have 1x4.120 rads per GPU. Please clarify for a thicky like me...
HAving a look around mate there seems to be more Rei models in the type of pose that would look OK in the tube, Im guessing Asuka is in with the color scheme tho.
Maybe have a look on eBay at some of the garage kits?
