This was my 1st real build from scratch.....
Spec....
SilverStone TJ03
Asus P5Q-E
Intel e8400 core 2
Artic pro 7
OCZ 700w modular psu
Kingston Hyper X 8500
Samsung F1 1tb
XFX 4870 1 gig
SilverStoneTJ03
The assemble was made nice and easy with the TJ03's removable MoBo
and it wasn't long until I was slotting the tray back into the case.
Tried to keep the cable management as neat as possible.....
My Build booted straight to the BIOS and reformatted the drive and installed XP with no problems....I have had the build up and running for about 2 weeks. Temps are great and all running at stock....I have since got rid of the 4870 and have the 4890xt sitting in the rig now....
I do however have a few questions.... The TJ03's front intake fan has 2 types of power connectors, one is the brown 3 pin that drops onto the MoBo, the other is a white 4 pin connector that plugs straight to the PSU...I have both connected, is this wrong? should I just use the PSU connector?
I have also bought another hard drive, a SATA seagate 160 gig....The idea is to run my OS on the Seagate and keep the Sammy for my everyday use.(game applications ect)
The sammy is plugged into the sata 1 port on my MB...So is it just a question of removing the sata 1 cable from the back of the sammy and plugging it nto the back of the seagate 160gig, taking a new sata cable plugging it into the stat 2 port on my MB and the other end into the sammy, doing a reformat of both drives and OS installation on the new seasgate....will my PC now read the new seagate as Drive C amd my sammy as drive E?
I also want to buy a new sata DVD drive, do I just use another sata cable plug into the sata 3 port on my MB and the other end into the DVD drive, will the PC read this as drive F?
Do I also need to buy a power connector for the drive? or does the white 4 pin psu power adapter fit straight into the DVD drive?
Can any one recommend me a good quality Sata DVD drive plz....
Thanks for any help, hope you like my pics of my build......
Spec....
SilverStone TJ03
Asus P5Q-E
Intel e8400 core 2
Artic pro 7
Samsung F1 1tb
XFX 4870 1 gig
SilverStoneTJ03
