More of an update should be forthcoming in the near future. Started taking it apart to get a photo and discovered that the tubing coming into the 10W pump is pretty much flat. This suggests lower pressure in this pipe, and the tubing recovers if the 10W pump is turned off. Not worked out what this implies yet. Probably just that I don't want a long, curved, flexible intake tube going into the impeller of a ddc, but it also suggests that the pressure in parts of the loop is fairly high. This probably means it's a good time to put things in parallel.
Some research into centrifugal pumps suggests I'll be alright with two matched pumps adjacent to each other, so I think I'll try that before any extensive rebuilding. Need to get the psu out somehow (difficult) to change the pvc tape for a K200 pad. Have another radiator on the way for good measure too. Realized I don't have any pictures up of the assembled case yet, so should change that.
