- 26 Aug 2010
- West Yorkshire
Hey guys,
So, this is my first proper high end build, and my first foray into watercooling. My current rig was a pre made custom rig, and I've upgraded everything in it. The only thing left is the hard drive
Current Build (Upd. 12/06/2013)
Well, here it comes!
Confirmed:
Case: Corsair 900D
Power Supply: XFX Pro 1000w 80+ Platinum
SSD: Samsung 840 Pro 512GB
Headset: Corsair Vengeance 2000
Speakers: Edifier R1600T
CPU: 4770k
GPU: Nvidia GTX 780
Motherboard: Gigabyte Z87X-OC
RAM: TeamGroup Vulcan Orange 2133Mhz 2x8GB
Watercooling: Tubing size not yet planned.
Radiators: 2x 480mm 60mm
CPU Block: Aqua Computer Cuplex Kryos XT
GPU Block: Aqua Computer Kryographics for GTX 780
Fans: 8x Scythe GT 1850
Pump: Aqua Computer Aquastream XT Ultra USB
Resevoir: 2x FrozenQ Liquid Fusion White tubed custom
Tubing: Primochill Primoflex Advanced Tubing - White
Fittings: Monsoon Orange compression fittings
Coolant: Aqua Computer Double Protect Ultra Clear or distilled water.
Concepts:
Original FT02 Build:
900D Concept:
I'll be going for a white alternative to that instead of green now.
External Power Switch:
The case will be at the back of the room behind the desk, so for ease of access i am building up an external power switch using a spare PCI bracket, some buttons and a stereo cable between the PC and the box.
When the cable in the back is removed, the circuit breaks and gives functionality back to the case power and reset.
Concept:
Progress:
11/06/2013 and earlier
12/06/2013
Ok, started my first attempt at sleeving a spare cable...
But it failed!
Yeah... I put it too close to the hob and melted the plastic lol. I did better on the other side though.
TBC...
And here it comes...
Headset arrives! (With the 3.5mm cable for the power thingy
Haribo!
One of these is mine
And here it is!
It's Massive!
PSU and SSD Arrive too.
PSU unboxing:
Speakers came a while back:
12/06/2013
And it emerges out of the box from whence it came!
Placed on my desk.
The box takes up half of my room. Nowhere else to put it yet though... It doesn't even fit through the door to the loft where everything else is kept.
Shiny fans
"Installed" the PSU and the SSD
I "Stole" some grommets from my CM 690 II
They fit exactly as I hoped. When i cover up all the unused holes, these will do nicely for the 8pins to hide the open holes at the top.
I think I'll look for some sleeving for the PSU next while I wait for the motherboard that I want to be released
Update: 19/06/2013
A few changes to my build:
I'll be doing for a black background as usual with white as a secondary colour, but adding orange highlights. I can get a cheaper board now that is still good, and fits in with the colour scheme. I can also use the orange square on my SSD. This adds a splash of warmth to the build
I got my sleeving and utilities and a 4pin extension to test on.
here's the "before" shot:
The ATX pin remover tool
Unfortunately it didn't manage to remove a single pin... So I picked up some paperclips and made my own tool
measuring the wire length for sleeving
voila!
Managed to stick on the ends and stop them fraying with contact adhesive. Let's see if it lasts
All sleeved! Looks better than I first expected. (I have orange and white heat shrink as a backup)
The money shot:
I also got some larger grommets as an alternative at the top. Big thanks to ToxicTBag (Tony)!
Confirmed:
Case: Corsair 900D
CPU: 4770k
GPU: Nvidia GTX 780
Concepts:
900D Concept:
Concept:
Progress:
12/06/2013
But it failed! Yeah... I put it too close to the hob and melted the plastic lol. I did better on the other side though.
TBC...
)Haribo!
And here it is!
It's Massive!
PSU unboxing:
12/06/2013
Placed on my desk.
Shiny fans
They fit exactly as I hoped. When i cover up all the unused holes, these will do nicely for the 8pins to hide the open holes at the top. I think I'll look for some sleeving for the PSU next while I wait for the motherboard that I want to be released
Update: 19/06/2013
voila!
The money shot:
