Project: Parvum
Did some overclocking on the 7950. Temps are around 75c when stressed and the stock cooler makes it sound like a leaf blower. Need to get it underwater soon...
Not really anything that interesting today as all I did was put my hardware into the case :p
Look what TNT brought me!
A few extras that were included with the case
Mystery bag
This is where a photo of the case would go, if I had remembered to take one...
Nice and simple HDD mounting. Simply slots into place :)
Motherboard in
GPU installed
This is one of the only issues I had with the case but it's still an extremely annoying one. Since the plastic above the PCI slots is directly in line with the hold-down screws, you have to remove the entire back panel and pull back the metal mounting plate to get the screws in... A PITA, to say the least.
Cable monster
Tidied up and hidden
Windowed side panel back on with everything installed :D
Installed the rubber case feet
Watercooling goodness coming soon!
Apologies for the lack of updates, I've been really busy with tying up loose ends with coursework. Only a few weeks left of college and then I can get the watercooling side of things done! :)
Mystery keyboard!
GPU waterblock
New case idea? ;)
D5 cables cut down and sleeved
Pump mounting holes drilled
Pump installed into the case floor
Mounted within the cable monster
Made up an LCD water temperature sensor!
Getting ready to cut
LCD installed
Also added a fill port whilst I was at it :p
